08-03-2019 06:29 AM
after I connect my SFP to LC connector with another SFP on other side how do i check the data rate in communication.
Also how will i be able to select the speed of my communication from 5Gbps to 10Gbps.
08-03-2019 07:07 AM
SFPs operate at a fixed signaling rate and cannot be changed.
You can verify the operating rate with the "show interface status" command against the interface in question.
08-04-2019 09:18 PM
08-03-2019 07:27 AM - edited 08-03-2019 07:27 AM
we have SFP speeds from 1GB / 10GB / 20_ mgig modules
depends on what SFP you use to connect each other, they will operate on fixed modes.
But if you like to lower them you can make arrangement lower them by configuration(plocy or shaping) . but it can not go above level of fixed rate.
