08-22-2011 09:05 AM
We have a Cisco Nexus 4000 switch with the following transcievers and I can't get a link to other 850 nm, sr, mm interfaces.
sho interface ethernet 1/15 transceiver
Ethernet1/15
sfp is present
name is FINISAR CORP.
part number is FTLX8571D3BCL
revision is A
serial number is AL404N7
nominal bitrate is 10300 MBits/sec
Link length supported for 50/125um fiber is 82 m(s)
Link length supported for 62.5/125um fiber is 26 m(s)
cisco id is --
cisco extended id number is 4
hchassis# sho int eth1/15
Ethernet1/15 is down (SFP validation failed)
Hardware: 1000/10000 Ethernet, address: 0027.0d24.305e (bia 0027.0d24.305e)
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Encapsulation ARPA
Port mode is access
full-duplex, 10 Gb/s, media type is 10g
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
Last link flapped never
1 minute input rate 0 bits/sec, 0 packets/sec
1 minute output rate 0 bits/sec, 0 packets/sec
Rx
0 input packets 0 unicast packets 0 multicast packets
0 broadcast packets 0 jumbo packets 0 storm suppression packets
0 bytes
Tx
0 output packets 0 multicast packets
0 bytes
0 input error 0 short frame 0 watchdog
0 no buffer 0 runt 0 CRC 0 ecc
0 overrun 0 underrun 0 ignored 0 bad etype drop
0 bad proto drop 0 if down drop 0 input with dribble
0 input discard
0 output error 0 collision 0 deferred
0 late collision 0 lost carrier 0 no carrier
0 babble
0 Rx pause 0 Tx pause
0 interface resets
I have attached the sho run all output. Any idea why I can't get an link out of this? Thank you very much for your time.
08-22-2011 10:22 AM
Is the SFP installed in the device a Cisco labelled product or a third-party labelled device? Cisco SW runs a check to verify the SFP is compatible before allowing it to operate.
08-22-2011 01:20 PM
I am assuming even thought the website claims that the FTLX8571D3BCL is Cisco compatible, that it is not. And the
"sho interface ethernet 1/15 transceiver" repsonse "cisco id is --" is proof of that?
I saw some other FTLX8571D3BCL online that had -cs added to the model number. I am guess this difference in model number has caused our failure? I have no clue. All I know is it won't link.
Nowhere on the device does it say Cisco. Thank you.
