show interface gi0/1/0 tranceiver : interprétation de valeurs
Dears
I have this output ; the SFP is ZX  at one side and LH on the other side ; are this value correct or acceptable
Port (dBm)         Optical Receive              High Alarm                High Warn             Low Warn                  Low Alarm
                           Power (dBm)                Threshold (dBm)         Threshold(dBm)    Threshold(dBm)       Threshold(dBm)
Gi0/1/0                     -12.5                           0.0                            -3.0                        -23.0                     -27.2
1 ACCEPTED SOLUTION
Hall of Fame Expert
Re: show interface gi0/1/0 tranceiver : interprétation de valeurs
Hello Abdel,
the output shows a received power of -12.5 dBm that is acceptable as it is not too high and not too low (High warning is -3 dBm and low warning is -23 dBm).
The only concern is that you are using two different types of optic SFP with ZX that is more powerful and that potentially might send too much power to other side.
You need to check this on both sides. Only if acceptable in both sides you should go on. Otherwise you should use the same type of optics on both sides.
Edit:
I see that the output is related to the ZX SFP side. Check the other side because it is likely that is receving too much optical power. If this happens the other side is not able to discriminate 0 and 1 digits. (it is made blind or saturated)
Hope to help
Giuseppe
3 REPLIES 3
Hall of Fame Expert
Hello Abdel,
Edit:
Hope to help
Giuseppe
thank you that' s right
Beginner
Content for Community-Ad
July's Community Spotlight Awards
