09-09-2020 01:49 AM
Hello together,
are there any knowm issues on compatibility for the original Cisco SFP-10G-SR-S and the C9500 Series switches?
We have the problem, that the inserted SFP+ are recognized as 1000BaseZX SFP and are in a non-functional state.
Working C9500 in the US running IOS 16.9.3, the interfaces show in inventory:
NAME: "TwentyFiveGigE1/0/24", DESCR: "SFP+ 10GBASE-SR"
PID: SFP-10G-SR-S , VID: V01 , SN: AVD2147DCD3
NAME: "TwentyFiveGigE2/0/24", DESCR: "SFP+ 10GBASE-SR"
PID: SFP-10G-SR-S , VID: V01 , SN: AVD2147DCDC
Not working ones, even after upgrading the switches to the most current version, Cisco recommended IOS (IOS XE Software, Version 16.12.04)
It appears these may be the wrong gbic, as they are displayed as SFP-10G-SR instead of SFP-10G-SR-S.
NAME: "TwentyFiveGigE1/0/48", DESCR: "GE ZX"
PID: SFP-10G-SR , VID: V03 , SN: AVD2231D3TE
NAME: "TwentyFiveGigE2/0/48", DESCR: "GE ZX"
PID: SFP-10G-SR , VID: V03 , SN: AVD2231D3RW
It seems that the modules are manufactured by the same company for Cisco, all of them are AVDxxxxxxxxx.
These are original Cisco SFP+, no third party modules!
Shall we return these SFP+ ?
Kind regards
Stefan
Solved! Go to Solution.
09-09-2020 02:09 AM
That sounds like a bug.
Have you raised this issue with TAC?
09-09-2020 02:09 AM
09-09-2020 02:32 AM
Hi Leo,
At the moment no, but we will do this, if there is no workaround available. In the bug tool there is no such issue present, so it seems something new.
Kind regards
Stefan
09-09-2020 08:51 AM
We have installed a workaround by using thirdparty modules now, but we have installed the failing modules as well, so a TAC case can be opened on them.
Kind regards
Stefan
09-09-2020 04:09 PM
If you replaced the SFP, changed the fiber patch, upgraded the firmware, the last call is TAC
09-09-2020 04:49 PM
Please post the complete output to the following command:
show idprom interface <PORT> detail
09-10-2020 03:17 AM
Hello Leo,
that's the output of the command:
IDPROM for transceiver TwentyFiveGigE1/0/27:
Description = SFP or SFP+ optics (type 3)
Transceiver Type: = GE ZX (23)
Product Identifier (PID) = SFP-10G-SR
Vendor Revision = A0
Serial Number (SN) = AVD2231D3TE
Vendor Name = OEM
Vendor OUI (IEEE company ID) = 00.00.00 (0)
CLEI code = COUIA8NCAA
Cisco part number = 10-2415-03
Device State = Enabled.
Date code (yy/mm/dd) = 19/12/13
Connector type = LC.
Encoding = 8B10B (1)
Nominal bitrate = OC12/STM4 (600 Mbits/s)
Minimum bit rate as % of nominal bit rate = not specified
Maximum bit rate as % of nominal bit rate = not specified
The transceiver type is 23
Link reach for 9u fiber (km) = IR-2(40km) (40)
LR-1(40km) (40)
DX(40KM) (40)
HX(40km) (40)
Link reach for 9u fiber (m) = IR-2(40km) (255)
LR-1(40km) (255)
LR-2(80km) (255)
LR-3(80km) (255)
DX(40KM) (255)
HX(40km) (255)
ZX(80km) (255)
VX(100km) (255)
Link reach for 50u fiber (m) = SR(2km) (0)
IR-1(15km) (0)
IR-2(40km) (0)
LR-1(40km) (0)
LR-2(80km) (0)
LR-3(80km) (0)
DX(40KM) (0)
HX(40km) (0)
ZX(80km) (0)
VX(100km) (0)
1xFC, 2xFC-SM(10km) (0)
ESCON-SM(20km) (0)
Link reach for 62.5u fiber (m) = SR(2km) (0)
IR-1(15km) (0)
IR-2(40km) (0)
LR-1(40km) (0)
LR-2(80km) (0)
LR-3(80km) (0)
DX(40KM) (0)
HX(40km) (0)
ZX(80km) (0)
VX(100km) (0)
ESCON-SM(20km) (0)
Nominal laser wavelength = 1310 nm.
DWDM wavelength fraction = 1310.0 nm.
Supported options = Tx disable
Tx fault signal
Loss of signal (standard implementation)
Supported enhanced options = Alarms for monitored parameters
Software Tx disable
Software Tx fault monitoring
Software Rx LOS monitoring
Diagnostic monitoring = Digital diagnostics supported
Diagnostics are internally calibrated
Rx power measured is "Average power"
Transceiver temperature operating range = not specified
Minimum operating temperature = 0 C
Maximum operating temperature = 70 C
High temperature alarm threshold = +75.000 C
High temperature warning threshold = +70.000 C
Low temperature warning threshold = +0.000 C
Low temperature alarm threshold = -5.000 C
High voltage alarm threshold = 3630.0 mVolts
High voltage warning threshold = 3465.0 mVolts
Low voltage warning threshold = 3135.0 mVolts
Low voltage alarm threshold = 2970.0 mVolts
High laser bias current alarm threshold = 11.800 mAmps
High laser bias current warning threshold = 10.800 mAmps
Low laser bias current warning threshold = 5.000 mAmps
Low laser bias current alarm threshold = 4.000 mAmps
High transmit power alarm threshold = 1.7 dBm
High transmit power warning threshold = -1.3 dBm
Low transmit power warning threshold = -7.3 dBm
Low transmit power alarm threshold = -11.3 dBm
High receive power alarm threshold = 2.0 dBm
High receive power warning threshold = -1.0 dBm
Low receive power warning threshold = -9.9 dBm
Low receive power alarm threshold = -13.9 dBm
External Calibration: bias current slope = 1.000
External Calibration: bias current offset = 0
SFP IDPROM Page 0xA0:
000: 03 04 07 00 00 00 02 12 00 01
010: 00 01 06 00 28 FF 00 00 00 00
020: 4F 45 4D 20 20 20 20 20 20 20
030: 20 20 20 20 20 20 00 00 00 00
040: 53 46 50 2D 31 30 47 2D 53 52
050: 2D 53 20 20 20 20 41 30 20 20
060: 05 1E 00 36 00 1A 00 00 41 56
070: 44 32 32 33 31 44 33 54 45 20
080: 20 20 20 20 31 39 31 32 31 33
090: 20 20 68 F0 01 37 00 00 06 C6
100: 89 54 31 1E 4C D4 F6 D5 28 AF
110: A7 D5 A3 21 A2 00 00 00 00 00
120: 00 00 00 00 6C 4F FF 5C 49 50
130: 55 49 41 4C 4B 52 41 41 31 30
140: 2D 32 31 34 34 2D 30 31 56 30
150: 31 20 01 00 46 00 00 00 00 E8
160: 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00
190: AA AA 47 4C 43 2D 45 58 2D 53
200: 4D 44 20 20 20 20 20 20 20 20
210: 20 20 31 36 00 00 00 00 00 00
220: 00 00 00 58
SFP IDPROM Page 0xA2:
000: 4B 00 FB 00 46 00 00 00 8D CC
010: 74 04 87 5A 7A 76 17 0C 07 D0
020: 15 18 09 C4 39 C7 02 E5 1C F5
030: 07 46 3D E9 01 97 1F 07 03 FF
040: 00 00 00 00 00 00 00 00 00 00
050: 00 00 00 00 00 00 00 00 00 00
060: 00 00 00 00 00 00 00 00 3F 80
070: 00 00 00 00 00 00 01 00 00 00
080: 01 00 00 00 01 00 00 00 01 00
090: 00 00 00 00 00 10 9D 15 5D 82
100: 5D 00 66 01 00 00 00 00 00 00
110: B2 00 05 40 00 00 05 40 00 00
120: FF FF FF FF FF FF FF 01 43 4F
130: 55 49 41 38 4E 43 41 41 31 30
140: 2D 32 34 31 35 2D 30 33 56 30
150: 33 20 01 00 46 00 00 00 00 C6
190: AA AA 53 46 50 2D 31 30 47 2D
200: 53 52 20 20 20 20 20 20 20 20
210: 20 20 32 33 00 00 00 00 00 00
220: 00 00 00 35 15 1A 20 24 2A 30
230: 20 30 00 00 00 00 00 00 00 00
240: 00 00 00 00 00 1D 00 00 FF FF
250: FF FF 00 00 00 00
Interesting is the wavelength of 1310nm, which is not a SR typical value of 850nm
Stefan
09-10-2020 03:31 AM
Leo,
thats an output of working ones at the USA from the same manufacturer:
IDPROM for transceiver TwentyFiveGigabitEthernet1/0/21:
Transceiver Type: = SFP+ 10GBASE-SR (273)
Product Identifier (PID) = SFP-10G-SR-S
Vendor Revision = G4.1
Serial Number (SN) = AVD2304DEPX
Vendor Name = CISCO-AVAGO
Vendor OUI (IEEE company ID) = 00.17.6A (5994)
CLEI code = CMUIAK6CAA
Cisco part number = 10-3105-01
Date code (yy/mm/dd) = 19/02/20
Encoding = 64B/66B (6)
Nominal bitrate = (10300 Mbits/s)
The transceiver type is 273
Link reach for 9u fiber (km) = SX(550/270m) (0)
1xFC-MM(500/300m) (0)
2xFC-MM(300/150m) (0)
ESCON-MM(2km) (0)
Link reach for 9u fiber (m) = SX(550/270m) (0)
ESCON-MM(2km) (0)
Nominal laser wavelength = 850 nm.
DWDM wavelength fraction = 850.0 nm.
Tx fault signal
Software Tx disable
High laser bias current alarm threshold = 10.500 mAmps
High laser bias current warning threshold = 10.500 mAmps
Low laser bias current warning threshold = 2.500 mAmps
Low laser bias current alarm threshold = 2.500 mAmps
External Calibration: bias current slope = 0.000
000: 03 04 07 10 00 00 00 00 00 00
010: 00 06 67 00 00 00 08 02 28 1E
020: 43 49 53 43 4F 2D 41 56 41 47
030: 4F 20 20 20 20 20 00 00 17 6A
040: 53 46 42 52 2D 37 30 39 53 4D
050: 5A 2D 43 53 32 20 47 34 2E 31
060: 03 52 00 40 00 1A 00 00 41 56
070: 44 32 33 30 34 44 45 50 58 20
080: 20 20 20 20 31 39 30 32 32 30
090: 20 20 68 F0 03 58 00 00 06 A1
100: FD D3 0E 68 14 DE 26 DE FA FB
110: 32 83 29 E3 7A 00 00 00 00 00
120: 00 00 00 00 35 87 C4 53 00 00
130: 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00
200: 00 00 00 00 00 00 00 00 00 00
210: 00 00 00 00 00 00 00 00 00 00
220: 00 00 00 00
010: 74 04 87 5A 7A 76 14 82 04 E2
020: 14 82 04 E2 39 C7 02 E5 1C F5
060: 00 00 00 00 00 00 00 00 00 00
070: 00 00 00 00 00 00 00 00 00 00
080: 00 00 00 00 00 00 00 00 00 00
090: 00 00 00 00 00 51 0E 19 78 82
100: 0A 0C D2 16 E2 14 00 00 00 00
110: B2 00 00 40 00 00 00 40 00 00
120: 00 00 1D 00 00 00 00 00 43 4D
130: 55 49 41 4B 36 43 41 41 31 30
140: 2D 33 31 30 35 2D 30 31 56 30
150: 31 20 01 00 46 00 00 00 00 B8
200: 53 52 2D 53 20 20 20 20 20 20
210: 20 20 30 32 00 00 00 00 00 00
220: 00 00 00 72 1E 20 2A 2A 31 34
230: 29 36 00 00 00 00 00 00 00 00
240: 00 00 00 00 00 56 00 00 FF FF
Kind regards
Stefan
10-11-2020 11:31 PM
I was looking for the same info, tried doing the same but it didn't worked. Thanks for spreading the knowledge walgreenslistens
10-12-2020 03:21 AM
Hello.
It works fine with 16.12.02 version
So-9500-core#sh inv | i SFP-10G-SR-S
So-9500-core#sh ver | i 16.12
Cisco IOS XE Software, Version 16.12.02
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.12.02, RELEASE SOFTWARE (fc2)
So-9500-core#
About possible causes of malfunction:
1) it is necessary to check grounding (9500 switches are very sensitive to it);
2) you can try disabling and enabling problem port.
3)is this sfp 10G original or not?
10-12-2020 08:47 AM
Thanks everyone for discussing this topic. The SFP+ are wrong branded, original Cisco SFP+. All defective SFP+ are replaced now and the new original ones are working - by the way they are now from Finisar, instead of Cisco Avago. I don't know why Cisco choosed Avago for manufacturing them.
Thanks a lot.
Kind regards
Stefan
01-13-2021 03:52 AM
Do you have sfp pictures and idprom output I have same problems
thank you
01-13-2021 06:55 AM
Sorry,
I only posted the output of the idprom. I didn't took pictures from them.
As you can read, they were wrong branded and identified as "GE-ZX"
Cisco replaced them and everything is fine now
Have a nice day
Kind regards
Stefan
01-13-2021 08:37 AM
But my transceiver still can't use
Vendor name is cisco-avago
Transceiver type is SFP+ 10Gbase-SR
Which model I need to change for C9500 24y4c?
01-24-2021 05:51 AM
Hi Folks,
It is a normal issue.
Just interchange the LC connecting the SFP+. It works just fine.
Check: show idprom interface Interface name
Show interfaces Interface name transceiver detail
Please note that the SFP+ module should be detected by the device.
The version of the C9500 switch we are running is:
CoreSwitch_01#show ver
Cisco IOS XE Software, Version 16.09.05
Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.9.5, RELEASE SOFTWARE (fc1)
