ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
Turn ON digital optical monitoring (DoM)
How to turn on this feature? Chassis supports it (3750). Transceiver supports it, as Digital Optical Monitoring Compatibility Matrix said (GLC-ZX-SM). But "sh inter gi1/0/25 transceiver detail" show me "Diagnostic Monitoring is not implemented." message. What I should do to implement collecting DOM info?
And second. Is 6500 with IOS supports this feature? CatOS supports, as Cisco site said. But IOS (now we have 12.2(18)SXF line) shows me message "Diagnostic Monitoring Data is not available." (also GLC-ZX-SM)
8 REPLIES 8
Highlighted
Rising star
Re: Turn ON digital optical monitoring (DoM)
RE: 3750
Does your IOS software support the feature? I found in release notes that for 3750, DOM is supported starting in 12.2(44)SE.
Highlighted
Beginner
Yes, it's 12.2(46)SE. However, in another Cisco page I found that GLC-ZX-SM has NOT DOM support. So it's contradiction.
Highlighted
Beginner
Hi...
Have you tried the following commands (done from one of our 6503-E's running 12.2(33)SXI) :
r-s-bdr-2#show inter transceiver supported-modules
Mod DOM support
1 Applicable
2 Applicable
3 Applicable
r-s-bdr-2#show inter transceiver supported-list
Transceiver Type Cisco p/n min version
supporting DOM
DWDM GBIC ALL
DWDM SFP ALL
RX only WDM GBIC ALL
DWDM XENPAK ALL
DWDM X2 ALL
DWDM XFP ALL
CWDM GBIC NONE
CWDM X2 ALL
CWDM XFP ALL
XENPAK ZR ALL
X2 ZR ALL
XFP ZR ALL
Rx_only_WDM_XENPAK ALL
XENPAK_ER 10-1888-04
X2_ER ALL
XFP_ER ALL
XENPAK_LR 10-1838-04
X2_LR ALL
XFP_LR ALL
XENPAK_LW ALL
X2_LW ALL
XFP_LW NONE
XENPAK SR NONE
X2 SR ALL
XFP SR ALL
XENPAK LX4 NONE
X2 LX4 NONE
XFP LX4 NONE
XENPAK CX4 NONE
X2 CX4 NONE
SX GBIC NONE
LX GBIC NONE
ZX GBIC NONE
CWDM_SFP ALL
Rx_only_WDM_SFP NONE
SX SFP 1000 ALL
LX SFP 1000 ALL
ZX SFP 1000 ALL
SX SFP 100 NONE
LX SFP 100 NONE
ZX SFP 100 NONE
GIgE BX U SFP ALL
GigE BX D SFP ALL
Highlighted
Beginner
#show inter transceiver ?
detail Show interface transceiver detail
module Limit display to interfaces on module
threshold Show interface transceiver threshold info
| Output modifiers
It's SXF line, not SXI.
Highlighted
Beginner
It looks like the "supported-list" sub-command appeared in the SXH line. Anyway, from my output it appears DOM is not supported at all with the ZX SFP tranceiver :
ZX SFP NONE
Highlighted
Hall of Fame Community Legend
You need to get the Rugged-ized GLC-SFP (1Gig) to have DOM enabled.
Highlighted
Beginner
your SFP's need to have the DOM
have a look on the SFP data sheet:
http://www.cisco.com/en/US/partner/prod/collateral/modules/ps5455/ps6577/product_data_sheet0900aecd8033f885.html
exemple:
GLC-SX-MM is without DOM
GLC-SX-MMD with DOM
for your GLC-ZX-SM, you need the GLC-ZX-SM-RGD SFP's.
Highlighted
In layman's terms it depends on SFP whether DOM or Diagnostic Monitioring will be implemented or available... I also believe which IOS you are on matters also but don't hold me to that...
