We have some X2-10GB-SR v04 that we noticed that the FTLX8541E2-C4 versions include the diagnostic monitoring DOM support. However, the FTLX8541E2-C2 parts do not. I haven't been able to find any part disclaimers showing some of the v04 do not include DOM... All the compatibility docs I've seen state SR support DOM. Am I missing something?
When I enter "show int tran" for the C2 parts there is no output...
The C2 and C4 look entirely the same and are both v04.
Did the X2-10GB-SR not support DOM until C3 or later?
Transceiver vendor name :CISCO-FINISAR
Part number provided by transceiver vendor :FTLX8541E2-C2
Revision level of part number provided by vendor :A
Vendor serial number :FNS14111L2X
Vendor manufacturing date code :2010030801
Digital Optical Monitoring Capability Byte :0x0
Digital Optical Monitoring :Not Implemented
Part number provided by transceiver vendor :FTLX8541E2-C4
Vendor serial number :FNS14270BJB
Vendor manufacturing date code :2010062801
Digital Optical Monitoring Capability Byte :0xC1
Digital Optical Monitoring :Implemented
