10G SFP no link on Catalyst 1200
gorankarlsson
Hi everyone,
I have two Catalyst C1200-48T-4X with SFP-10G-LR each.
Transceivers are recognized as they should but we get no link. We have checked the connection, administrative state is up, each switch/SFP is transmitting light and transceivers are recognized in both ends. Inserted in ge49/te1 slot.
We have verified with another switch brand and with similar SFP+ transceivers, no problem, link goes up. Optical values very good.
Anything I can missed? Are there differences between SFP slots? Anything else?
7 Replies 7
marce1000
 - Have you checked if the SFP model is compatible with the switch according to :
        https://tmgmatrix.cisco.com/
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
No, C1200 doesn´t show up with any 10G SFPs in that list. But Regarding to data sheet Cisco Catalyst 1200 Series Switches Data Sheet - Cisco, SFP-10G-LR is supported in C1200-48T-4X (SFP+).
 - Hm , normally  https://tmgmatrix.cisco.com/?npid=6094  is kind of authoritative ; from there only https://copi.cisco.com/?tpid=141 , is listed for 10G speed. If opinions vary , contact TAC
 M.
Thanks, I have contacted TAC and asked about confirmation regarding compatibility.
 - Ok , good to do : if you get any feedback , you may want to share here ; for future references and added value community content
 M.
I got the respond from TAC that the datasheet is correct, puh so the search for a solution goes on.
- Check software version on the devices , use latest advisory or try
utmost latest release , if there is still a no go with an advisory release,
M.
