01-18-2023 07:19 AM
Does anyone know if you can have a 10GBase-SR-S SFP+ connected to a 10GBase-SR SFP+? Specs look identical, just trying to get a definitive answer before purchasing.
Solved! Go to Solution.
01-18-2023 08:57 AM
Yes, they are interoperable for all LAN use cases.
01-18-2023 09:48 AM
Sure Only difference you see S- small factor ( do not support FCoE thats all) and cost effective compare to SR.
01-18-2023 08:57 AM
01-18-2023 09:48 AM
