10Gbps supports status
hamzashahid
Hi hope u all re fine
i have cisco switch WS-3560G-24PS-S 10/100/1000T PoE + 4 SFP ports
i want to know the speed of my sfp port do they support 10Gbps each
i have plugged in SFP module( AVAGO  AFBR-709ASMZ 850nm ) but its status showing is unknown because of not connected any wire through
Kindly guide me how will i know the speed without using or passing any traffic
Thanks & Best Regards:
HAMZA SHAHID
Leo Laohoo
3560G will not support SFP+.
3560X can support SFP+
Joseph W. Doherty
As Leo notes, the original 3560 series (which includes the "G" [for gig] variants, don't support 10g. BTW, there was one original 3750 model that did have one 10g port, but its ASIC only really had 8 Gbps capacity.) You would need the 3560E or later series (like the 3560-X, also mentioned by Leo) for 10G support.
