08-15-2005 01:05 PM
I am getting a MEA-AIP alarm on a 15454. I changed the AIP and still get the alarm. Has anyone experienced this before. Thanks.
08-15-2005 02:27 PM
You did not specify the type of chassis and Fan tray that you have.
It is possible that you are using an AIP card without a fuse with a chassis or fan tray that require 5amp fuse.
Change your AIP card to the AIP with fuse.
08-16-2005 01:53 PM
I am using the AIP with a 5 amp fuse. Is it possible I need the one without a fuse? ow do I tell by the part numbers on the fan and chassis? thanks for the reply
08-16-2005 04:19 PM
It is possible that you have a bad AIP card. But first try and resit your active TCC card at a maintenance window. If this does not fix the issue, replace AIP if you have a spare otherwise call Cisco TAC if you have support contract and have the AIP RMAed.
