50ft E1 cable (LOROM), requires 15305-PP-32E1 patch panel
ahmedtalaat
Please support to know the specs of which used for connecting the SDH (15310E-MA-SA=) to E1 patch panel (15305-PP-32E1-120=)
also please advise from where to buy
kayukovvalera
If you are talking about ONS 15305 you need to buy 15305-E1-63=. If you are need to demultiplex 63 E1 on ONS 15310 you need to buy:
- 1 x 15310-EIA-HD-A=
- 1 x 15310-EIA-HD-B=
- 2 x 3-rd party Telco 50-pin cable
Also you can find full specs in data sheet:
http://www.cisco.com/c/en/us/products/collateral/optical-networking/ons-15310-ma-sonet-multiservice-platform/product_data_sheet0900aecd80404d13.html
By the way, ONS 15305 and 15310 are EOL\EOS, it mean that you have to search part numbers in CCW or GPL price list witch end with RF=. RF= means refurbished, you have to contact with your local Cisco PAM\CAM to check global stock of ONS 15305\15310 parts.
so any idea from where to order that 3rd party telco cable.
Here is pinout for that cable:
http://www.cisco.com/c/en/us/td/docs/optical/15000r7_0/15310/15310_cl_ma/reference/guide/310ref70/3107insm.html
And short spec for telco-50 cable. Also you cab buy it at Molex, Amphenol or APC.
