8-port Muxponder with GE SMF Interface
ngss
Beginner
Beginner
I am proposing an ONS 15530 with 8-port Muxponder card (15530-MSMP-0112)
I need to connect to a Layer switch with GE using Single Mode Fiber.
Referring to product data sheet at
http://www.cisco.com/en/US/products/hw/optical/ps2011/products_data_sheet0900aecd801d2889.html
stated that only GE Multimode fiber )15454-SFP-GEFC-SX) is available.
Is there any interface that I can use for GE SMF?
SSng
aareed
Ngss,
The 15454-SFP-GEFC-SX SFP supports 1 Gig FC, 2 Gig FC, or 1 Gig Ethernet, and uses multimode.
However, there are 2 other SFP options for GigE that you can use that use Single Mode fiber:
15500-XVRA-11B21
High-temperature, Mid Band 200 Mbps to 1.25 Gbps
Single mode 9 and 125 micrometers
or
15500-XVRA-12B11
High-temperature, High Band 1.062 to 2.488 Gbps
Aaron Reed
Cisco Optical TAC
Thanks you so much for your responce. I will use 15500-XVRA-12B11
SSng
Recognize Your Peers
