Optics and Optical Networking
Engage with peer and Cisco experts about pluggable optics (Optics) and optical transport networks (Optical Networking).
Learn how to make your network more efficient when you transition to Routed Optical Network.
I currently have 2 nodes connected via single OC48 (used to carry 2 gige circuits). Node 1 uses the internal clock for timing, Node 2 is looking to the line for timing. Currently this config seems to work fine. Now i need to bring up a second oc48 fr...
We are looking at being offered a CWDM solution with the following specs. What equipment is needed to hook this up? I am not sure if we need a mux (i.e. CWDM-OADM4-1) or if we can use one of the SFP's (CWDM-GBIC-1550=) on a Cisco 3750 switch, or do...
We wish to extend our Ethernet connection from our POP to a remote site over a leased STM-1 circuit. A lot of suppliers had been suggesting different hardware like RAD RIC-155Ge (http://www.rad.com/10/Gigabit_Ethernet_over_STM_1_OC_3_NTU/2486/#), etc...
defash by Level 1
  • 883 Views
  • 3 replies
Hi All We have had three events where our OPT-Pre card goes into Alarm and the msg APC correction skipped comes up after either a power shutdown of an adjacent node or if the fiber span is worked on in either case the light becomes completly absent ...
I purchased 11 ONS15454Es and SW and I also can manage them with CTM.But now I want to upgrade the 15454E SW and CTM.So I checked the SW product list,and I have an questions below:whether is there any limitation(including the 15454E SW and CTM) if I ...
haijason by Level 1
  • 850 Views
  • 2 replies
