Optics and Optical Networking
Engage with peer and Cisco experts about pluggable optics (Optics) and optical transport networks (Optical Networking).
Learn how to make your network more efficient when you transition to Routed Optical Network.
Hi,<br /><br />We have a MDS9222i for SAN replication which needs to be directly connected with another MDS9222i over a WAN link(45Mbps). Is there some specific cards and cables which we might have to look into or do we have to use a seperate switch ...
Hi,i have catalyst express 500 switch with transceivers modules GLC-SX-MM, 1000BASE-SX SFP. Is possible to change the speed of this transceivers to 100Mbit? ... i need it know, because on other side of link is a opical/metallic converter ( AT-MC101XL...
I have an area of 250meters by 250.This is automobile workshop for car maintenance.I want to cover this area through wireless 2.4 Ghz (no dead spot).Hand held devices will be accessing the Access points of 1240 series.These Access points will be conn...
Running a 17 node ONS-15454, UPSR Ring with Software ver. 6.0.3.Why is it that when viewing or editing some circuits you do not see a Protect Path? On most circuits, you see a green working path and the purple protect path. We occasionally see circ...
Resolved! CSS 11506
I configured VIP on my CSS 11506. I created a content rule and a service, which will be used by the content rule. Both have been activated. However, when I do "show service summary", the new service created is not coming up, it's showing down. I remo...
We had an issue with one of our core 7606 routers. Bug ID: CSCsl50569 To prevent issue from occuring in 12.2(33)SRB2, diagnostics can be disabled on the SIP-400 with the following command: Router(config)#no diagnostic monitor module I would like to k...
aneesh.ts by Level 1
  • 567 Views
  • 1 replies
