Optics and Optical Networking
Engage with peer and Cisco experts about pluggable optics (Optics) and optical transport networks (Optical Networking).
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Learn how to make your network more efficient when you transition to Routed Optical Network.
Publicaciones del foro
Greetings to all,I am not experienced in fibre optics.I wish to connect (single mode) fibre optic cable to Fibre optic switch ( DIN-rail mounted) directly without using patchl panel or patch cords.I would also like to know what precautions should be ...
Hi,I need your help to know what command Can I use to display the power optics from  a interface on a switch WS-4507R+E Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 15.0(2)SG6, RELEASE SOFTWARE (fc1)Technical Su...
hhmaldon1 por Level 1
  • 15682 Visitas
  • 6 respuestas
  • 0 Útil
I have a switch with all four 10g optical links on a port channel showing -40.0 dBm Optical Receive Power. I believe this means it's not receiving a signal at all. I don't have physical access to the switch nor the device the port channel is connecti...
esa_fresa por Level 1
  • 1384 Visitas
  • 2 respuestas
  • 0 Útil
Autores con más Soluciones
