Hi,I have a query, I need connect a Switch 6500 with a switch HP, the switch HP has a HP X242 10 SFP module and need connect to the switch 6500 with a module CVR-X2-SFP10G. I need to know if this modules are compatible.Thanks for the help.
We have four 3750x Cisco Switches. We would like to connect our database serverto the switch via fiber connection. What would we need to purchase to do this? We have the Cisco 3750x-48T-S. We do not have any of the additional network modules.
Hello.I have a SM fiber run betwixt two X2-10GB-LRs. One side is seeing Rx power that could be better. I suspect the loss is somewhere in the fiber run but I dont have equipment to terminate the fiber with X2-10GB-LRs at various parts of the fiber ru...
Are there any interoperability between:cisco ONS 15454 with TXP_MR_2.5Gtransceiver GE SX/FC1-2G MM ONS-SE-G2F-SX V02 EXTandintel AFBR-703SDZ-IN2 850nm laser prod 21cfr(j) class 1 intel FTLX8571D3BCV-IT 850nm laser prod 21cfr(j) class 1
Datasheet says that MGBLX1's wavelenght is 1310nm but a couple measured to 1300nm. Faulty units or have the specs changed?
We need an Nexus-Chassis (L3!, capable for OSPF) which supports DWDM-Transceiver (10G) for interlinking with ONS15454-CardIs there any existing/new/upcomming NX-OS which supports this DWDM-Transceiver for Nexus 55xx ???in the PDF "Cisco 10-Gigabit Et...
Hi all,I need to know that if my storage environment (within 50mtrs) has 10Gig can i use UTP in place of fibers.Thats right that fiber have their own advantage of latency , speed, BW etc. but why not UTP ? Reply will be appreciated.
1 Question We have 3 ONS 15454 in A,B,C each place. The connection between different locations is a pair of single mode fiber. The topology is A>B>C>A. The A is main datacenter. We want to make a redundancy design based on ROADM. The normal transmi...
Hi all,Just for fun, I'd like to move to Fiber, running the trunk ports between my two Cisco SG300 lab swiches but I'm new to the media. Looking at the options, I thought that MM (MGBSX1) is the way to go, but the "Official" SFP's cost an arm and a l...
It began to blink when I changed the Fan 15454-CC-FTA=. At first I think it is in rebooting but it made this blinking for one day. That's a log in the alarm and it said "SLOT 2 improper removal". But I didn't even touch it. The blinking details are: ...
Just a small question..If we have a 10GB interface speed on a switch.. the SFPs all the same can support 1GB and 10GB or they're different models?Thanks,Ahmed
Hi, anyone knows why the interface remains up, when is receiving a lower power than the expected. Can we avoid this ?? how ?SPA-1X10GE-L-V2 with XFP-10GLR-OC192SRThe Receiver sensitivity (maximum) is 10GLR SR-1: -12.6 dBm We were receiving -20 but,...
Hi,It was mentioned that GLC-LH-SMD support both Single Mode and MultiMode fiber. I think it should be quite sure that it can support Single Mode since this is the only transceivers module that support Single Mode. Does anybody have experience using ...
HelloI need to know if this architecture is compatible.I put the diagram as an attachment.Thanks !Thibaud.
HiWe have multiple IBM Datapower XI52 boxes, with fiber conenctions.We can get transmit only, no receive talking to a 5k Switch, but if i move the same transceiver and cable to a 7k switch it works fine, and we can connect, transmit, receive, and pin...
| Subject | Author | Posted |
| 08-26-2025 11:25 AM | ||
| 07-16-2025 05:34 PM | ||
| 09-24-2024 09:19 PM | ||
| 07-25-2024 01:25 PM | ||
| 03-27-2024 12:16 AM |
