Optics and Optical Networking
Engage with peer and Cisco experts about pluggable optics (Optics) and optical transport networks (Optical Networking).
Learn how to make your network more efficient when you transition to Routed Optical Network.
I need to extend a demarc for a T3 for ~= 1 km and would like to use a FOM solution.  I have both SM and MM fiber available and I think I would like to utilize the MM given that this is a relatively short distance.  SNMP fault polling and trap genera...
jedavis by Level 4
  • 3101 Views
  • 4 replies
Hi Guys,I  am faced with the challenge of connecting 2 core switches located at  different building about 2 Km distance from to each other. I choose to have on one end, the  core switch WS-C3750-24TS-E  and the other end with same core switch WS-C375...
Hi ExpertsI  want to connect two san fabric switch away from each other 20KM using a  dedicated fiber in order to replicate san traffic , question is what  transceiver on san fabric should i use to terminate the fiber cable  coming from the MUX ,is S...
Hello team!Is it possible that the SFP-10G-LR will work with multimode fiber?I totaly understand that this actualy depends on cable type and lenght, but I do not have this information right now.So, if someone have succes or bad story I am happy to li...
