C9200-24p weird issue with gbic
tbasho
My end user uses small business switches CBS350-24FP-4G and is connecting with C9200-24P. GE Transceiver for SMB is MGBSX1 and from C9200 I use GLC-SX-MM. It wont link to each other unless I trick them by unplug and plug back other gbic from catalyst side.  Does anyone knows about this issue?
Not sure.
IOS-XE is riddled with optic module bugs.  If one version fixes it, another version will re-introduce the same bug.
16 Replies 16
 Any error message on the 9200 side?
no error
marce1000
  - Following https://tmgmatrix.cisco.com/?tpid=142 ,  GLC-SX-MM is not supported on your 9200 checkouthttps://tmgmatrix.cisco.com/?npf=341
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
Thanks for the info , I ordered two GLC-SX-MMD. I will update here with results.
I tried GLC-SX-MMD and still the same issue. Any other suggestion?
Leo Laohoo
Yes, it is a very widely known issue about optics and IOS-XE.
Cold reboot is the most common "recommended" workaround.
This is troubleshooting 101, I have tried and didn't work. Thanks
Loop the link to each other.  Does the port go up?
I put GLS-SX-MM in both side  and the link comes up .
What firmware is the 9200 on?
17.6.4
Please try either 17.6.5 or 17.9.3.
Do you think 17.6.5 will fix my issue ?
Not sure.
