03-30-2015 12:32 PM
Hi All,
On the Nexus 6004 series, does anybody know how to see the light levels for the optics.
I am using the command: show interface ethernet 2/5/4 transceiver details which outputs:
Ethernet2/5/4
transceiver is present
type is QSFP-40G-CSR4
name is CISCO
part number is AFBR-79EEPZ-CS2
revision is 02
serial number is XXXXXXXX
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM3 fiber is 300 m
Link length supported for 50/125um OM2 fiber is 82 m
cisco id is --
cisco extended id number is 16
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 47.63 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.32 V 3.63 V 2.97 V 3.46 V 3.09 V
Current 0.00 mA 0.00 mA 0.00 mA 0.00 mA 0.00 mA
Tx Power N/A N/A N/A N/A N/A
Rx Power N/A N/A N/A N/A N/A
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
Is it a case that the SFP's in this instance do not support the light level information? the controller, optics or wdm commands are not available on the Nexus.
Thanks all for your support.
03-30-2015 12:46 PM
Per the Cisco DOM Compatibility matrix, the QSFP-40G-CSR4 V02 is DOM-compatible and should thus show the power levels.
Can you tell me what NX-OS release you are running?
You might have to open a TAC case to see why the Tx and Rx levels aren't reporting properly.
03-30-2015 12:50 PM
Hi Marvin,
The System version: 6.0(2)N1(2)
Software
BIOS: version 2.6.0
loader: version N/A
kickstart: version 6.0(2)N2(2)
system: version 6.0(2)N2(2)
Power Sequencer Firmware:
Module 0: version v5.0
Module 1: version v2.0
Module 2: version v2.0
Module 3: version v2.0
Module 4: version v2.0
Fabric Power Sequencer Firmware: Module 0: version v3.0
Microcontroller Firmware: version v1.1.0.3
QSFP Microcontroller Firmware:
Module 1: v1.3.0.0
Module 2: v1.3.0.0
Module 3: v1.3.0.0
Module 4: v1.3.0.0
03-30-2015 12:57 PM
That is an early release (March 2013) and Cisco's current recommendation is 7.0(5)N1(1) (reference).
I couldn't find a published bug specific to DOM; but the TAC would be able to confirm via a search of the internal database.
03-30-2015 01:33 PM
OK, I shall proceed down this route as an IOS upgrade is not an option for us at the moment. Thanks very much for your help Marvin
