I don't know what EID-2330 means for the error message. But I can tell you if you're using the connection manager to build an end to end cross connect and allowing the system to autoroute the SONET or OCHNC, whatever you're trying to build, if you don't have the DCC (green lines) between your nodes then the route will not find. Conversely, if you're trying to build a OCHNC for a DWDM, if you select the wrong degree for the DWDM it will also fail to calculate the route.
If your network does not have DCC and you're building cross connect, then you'd have to build TL1-like cross connect and manually build each hop...
That's about all I can offer since the details are pretty vague on what you're trying to build.
-Tom
Please mark answered for helpful posts
http://blogs.cisco.com/smallbusiness/
