el 05-19-2015 07:35 PM
I need to connect a fiber between a WS-X6708-10GE module of a 6500-e chassis to a third-party Firewall. The Firewall has 10G SFP+ SR transceiver. I need to connect the two devices through a 10 Gbps link. I'm not sure if I can connect a GBIC to a SFP without problems and what model I should use. Some Reading, I have seen that the two modules must work in the same wavelength and type of fiber (MMF or SMF).
Currently, I have only 10GBase-LR installed at 6500:
Port Name Status Vlan Dúplex Speed Type
Te1/1 CONEXION TRONCAL C connected trunk full 10G 10Gbase-LR
Te1/2 SW_6509_VEN_A TE1/ connected trunk full 10G 10Gbase-LR
Te1/3 connect to ASR01VE connected routed full 10G 10Gbase-LR
Te1/4 PUERTO LIBRE, CONF disabled 1 full 10G 10Gbase-LR
But optionally I have some XENPAK-10GB-SR transceivers that I could use.
Please give me some advice about how can I do that connection?
Thanks a lot.
el 05-19-2015 08:21 PM
They will work as long as both fibre optic modules are of the same wavelength.
el 05-20-2015 06:55 PM
The selection of the optical transceiver to use is typically based upon the fiber distance between the devices being interconnected.
10GBASE-SR interface (which your firewall has installed) will support various link lengths, depending upon the grade of optical fiber connection the devices:
10GBASE-SR Module supports a link lengths of
If one of the above distances/fiber type matches your current installation, then use a Cisco 10GBASE-SX module, X2-style module for your 6708. If the above distances are not sufficient for your needs, you will need to move to a different optical module that meets your network.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
