Compatibility behind SFPs Avago, Dell x Cisco
thiagokalu
Community Member
Hi folks!
I need to connect a dell switch acess block with my catalyst 4506-E with sup7.
The catalyst uses a  WS-X4612-SFP-E module with GLC-SX-MM SFP, and the Dell switchs uses the AFBR-57R6AEZ-HP (Vendor Avago) and
FTLF8519P2BNL (Vendor Dell).
These two SFPs are a 850nm and class 1.
This communication will running ok? I trying to search the especifications of these SFPs but i'm not right about the perfect operation of this scenario.
Please help me guys!
[]'s
Leo Laohoo
The Cisco GLC-SX-MM will work with Cisco appliance.  Non-Cisco-branded will NOT work for Cisco appliance.
I'm not familiar with the other parts that you've mentioned but as long as they are the same type, i.  e.  multi-mode fibre that operates at 1000Base, then it will work.
It won't work if the other parts are Single-mode or will operate in speeds other than 1000Base.
