03-24-2021 09:03 AM
Guys I need help with this assignment and I'm new to this course
1) 2 2811 routers with serial interfaces
2) 2 2960 switches
3) 1 3560 multilayer switch (this is the routing device)
4) 4 end devices (2 connected to each 2960 switch)
5) 1 end device connected to each router
6) IP addressing; on Switch 1 (2960) 172.16.20.0 (host requirement 60 devices for each VLAN derived from the 172 address scheme) configure VLAN 100 Name Students and VLAN 300 Name Library
7) IP addressing; on Switch 2 (2960) continuation of 172.16.20.0 (host requirement is 100 devices for each VLAN derived from the 209 address scheme) configure VLAN 200 Name Faculty and VLAN 400 Name Staff
9) Router 1 addressing to server is 209.165.100.0/28
10) Router 2 addressing server is 192.168.100.0/26
11) use OSPF protocol to communicate across the network
12) 3560 switch is the routing switch for the layer 2 switches (2960). Configure routing for the VLANs on layer 3 switch.
13) Configure management VLAN 99 on each switch. 172.16.99.0
14) Configure an ACL to prevent ISP to access Faculty and Staff VLAN
15) Configure NAT translation from 3560 to ISP Router using 130.52.100.0 as the translated address.
03-24-2021 03:12 PM
The advice here is - This is your assignment, you need to put some effort into building the configuration of what you learning in the class, and apply the same thing in the config, when you stuck somewhere, ask question people in the community able to help you and make you understand and give a possible solution for you to fix and move forward.
This gradual learning makes you an expert at each level, so in real-world scenarios, you can able to handle yourself.
Google is your friend, many examples and youtube videos, many people posted many sample configurations.
