11-30-2011 11:41 PM
how do you determine what transceiver module (multimode or singlemode) is being used in a switch aside from pulling it out and seeing it the label on it?
is there a command for that in the CLI? existing switch is cisco 2950...
is it possible to determine if multimode or singlemode is being used just from the cables alone? i see some black-red and white-yellow fiber cable pairs. which one's which?
i appreciate the help! ^^
Solved! Go to Solution.
12-01-2011 06:13 PM
Below is a link to a document I keep of various transceiver commands.
Transceiver Query Notes
https://supportforums.cisco.com/docs/DOC-21008
I hope it helps!
12-01-2011 06:13 PM
I hope it helps!
