Digital Optical Monitoring - shutdown interface when attenuation is >17dB
brriapol
Team,
Is it difficult to write a script which performs a shutdown on a Cat3650 interface once attenuation has reached >17dB (29.5 is current in the output below)?
Thank you,
Switch#show interface transceiver
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                 Optical   Optical
           Temperature  Voltage  Tx Power  Rx Power
Port       (Celsius)    (Volts)  (dBm)     (dBm)
Gi1/1/1      29.4       3.30      -5.5     -29.5 --
salekar
Hi.
I believe it isnt difficult.
Here are some steps that you can follow :
-- telnet into CAT 3560 with proper credentials
-- issue the command "show interface transreceiver"
-- parse the output of the command for "RX POWER" and take its value in some variable.
-- compare it with 17
-- If its more than 17 then, issue the commands :
-- "configure terminal"
-- interface <interface number>
-- shut
-- exit
let me know if this helps.
