DOM with ASR 10 Gbps Interface
Marvin Rhoads
I am trying to figure out how to get optical power levels from an ASR 1006 with a XFP-10GLR-OC192SR transceiver in a SPA-1X10GE-L-V2 slot. I am running IOS-XE 3.5.2S (IOS Version 15.2(1)S2).
The command"show interface transceiver detail" is not supported. I cannot imagine this high end platform and transceiver can't report on optical power levels on its own.
19 Replies 19
Thank's
Marvin , your post eased my job of searching on support blog.
I work for service provider in Kingdom , had these new ASR's with Ios XE for testing and one shot with your post , i have the command to check the Optical Power.
Thx Marvin, much better that MIB - OID Gets.
Marvin,
Thank you so much man, you made my day easy today, with a simple google search I landed on your post.
Awesome!!!!
Kevynjr
@Kevynjr,
You're welcome. I'm glad it helped you.
damon.cooper
We have ASR 9001 routers in production and we use the following command for the following results...
sh controllers TenGigE  0/0/2/0 phy
 Temperature: 30.191
        Voltage: 3.272 Volt
        Tx Bias: 45.064 mAmps
        Tx Power:  1.10420 mW (0.43048 dBm)
        Rx Power:  0.21670 mW (-6.64141 dBm)
Note - the full output also shows the PID for the Optics
