07-21-2011 12:24 PM
Jul 21 18:52:36 UTC: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/4: Rx power high warning; Operating value: -5.5 dBm, Threshold value: -9.0 dBm.
Jul 21 19:02:36 UTC: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/4: Rx power high warning; Operating value: -5.5 dBm, Threshold value: -9.0 dBm.
Jul 21 19:12:37 UTC: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/4: Rx power high warning; Operating value: -5.5 dBm, Threshold value: -9.0 dBm.
NB: platform:
WS-C3750X-48P 12.2(55)SE1
Solved! Go to Solution.
07-21-2011 12:44 PM
-5.5 dB receive power is outside the target operating receive range, -9 to -28dBm, of the GE DWDM SFP. Although it will not damage the sfp, you may experience an increase in the bit errors. You can install a 10dB attenuator (or attenuated patchcord) at the receiver end to bring the optical receive power within the operating parameters of the DWDM SFP.
07-21-2011 12:44 PM
03-16-2014 06:43 PM
Hi Joseph,
I also had the same type of problem and refer Cisco TAC 629566213 for more details.
Here is the error message I got:
Mar 17 08:27:27: %SFF8472-5-THRESHOLD_VIOLATION: Te6/1/1: Tx power low alarm; Operating value: -40.0 dBm, Threshold value: -11.3 dBm.
Resolution was : Reset Interface hardware module
[switch <stack switch or switch number> frulink reloads
eg. switch 6 frulink reload
Janaka Wellege
