flapping link, tried everything, and still i can't find what is wrong
izzinwa
Got a flapping link between 2 of my MLSwitch (both are Cisco 6800-XL).
int Te7/3 on MLS_1 to int Te7/1 on MLS_2
the fiber connector on MLS_1 is SC, while the fiber connector on MLS_2 is LC
I have changed the fiber cable (Single-mode LC-to-SC) and I have also changed the transceiver/module (10G-BASE-LR on MLS_1 and SFP-10G-SR) but it is still flapping.
interestingly, only the int te7/3 shows flapping in its logs, while int Te7/1 on MLS_2 shows OSPF breaking/re-establishing (due obviously to the flapping link on the other end).
on MLS_1, i assumed int Te7/3 is prolly faulty, so i moved the connection from int Te7/3 to int Te7/2, but after moving it, the flapping still occurs.
# MLS_1 logs showing flapping
Feb 22 10:40:42.832 pst: %LINK-3-UPDOWN: Interface TenGigabitEthernet7/3, changed state to up
Feb 22 10:40:42.932 pst: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet7/3, changed state to up
Feb 22 10:55:14.942 pst: %LINK-3-UPDOWN: Interface TenGigabitEthernet7/3, changed state to down
Feb 22 10:55:15.022 pst: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet7/3, changed state to down
Feb 22 10:56:19.446 pst: %LINK-3-UPDOWN: Interface TenGigabitEthernet7/2, changed state to down
Feb 22 10:56:20.530 pst: %LINK-3-UPDOWN: Interface TenGigabitEthernet7/2, changed state to up
Feb 22 10:56:20.630 pst: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet7/2, changed state to up
Feb 22 11:07:46.111 pst: %LINK-3-UPDOWN: Interface TenGigabitEthernet7/2, changed state to down
# MLS_2 logs showing OSPF breaking due to flapping
Feb 22 10:40:44.945 pst: %OSPFv3-5-ADJCHG: Process 10343, Nbr 192.168.1.1 on TenGigabitEthernet7/1 from LOADING to FULL, Loading Done
Feb 22 10:40:47.705 pst: %OSPF-5-ADJCHG: Process 10343, Nbr 192.168.1.1 on TenGigabitEthernet7/1 from LOADING to FULL, Loading Done
Feb 22 10:55:15.590 pst: %OSPFv3-5-ADJCHG: Process 10343, Nbr 192.168.1.1 on TenGigabitEthernet7/1 from FULL to DOWN, Neighbor Down: Interface down or detached
Feb 22 10:55:15.590 pst: %OSPF-5-ADJCHG: Process 10343, Nbr 192.168.1.1 on TenGigabitEthernet7/1 from FULL to DOWN, Neighbor Down: Interface down or detached
Feb 22 10:57:01.538 pst: %OSPF-5-ADJCHG: Process 10343, Nbr 192.168.1.1 on TenGigabitEthernet7/1 from LOADING to FULL, Loading Done
Feb 22 11:07:51.962 pst: %OSPF-5-ADJCHG: Process 10343, Nbr 192.168.1.1 on TenGigabitEthernet7/1 from LOADING to FULL, Loading Done
The flapping lasts less than a second but it is enough to bring down ospf, and it turn it is disconnecting users who have sessions going on on that link.
Anyone seen anything like this? I am stumped, I have tried everything.
Do you think the problem could be because one end has a SR transceiver (LC connector) while the other end is a LR transceiver (SC connector)?
Should I change from a Single mode to a multimode fiber cable?
really appreciate any suggestions, thanks
