Gbic module for SGE2000
santos.martinez
Hello, I need to know which gbic modules are compatible SGE2000P SGE2000 and if I can connect those with a switch that has a module SRW2008P with MGBSX1.
Tom Randstrom
I found an old Linksys manual (attached) for the SGE2000/200P switches.  The SFPs that the system supports are as follows:
"Use the Linksys MGBT1, MGBSX1, or MGBLH1 mini-GBIC modules
with the Switch. The MGBSX1 and the MGBLH1 require fiber cabling
with LC connectors, while the MGBT1 requires a Category 5e Ethernet
cable with an RJ-45 connector."
Shouldn't be any problem connecting the two switches via MGBSX1 interfaces.
Hope this helps!
Tom
Ok, Thank you very much
