HELP NEEDED FOR CREATING CISCO ESTIMATE
adeebtaqui
Level 4
Level 4
Hi, I need help in creating cisco estimate as the cisco configuration tool has expired. I am going to the option of creating estimate but not getting any option for devices etc like in configuration tool, instead getting only preferences.
kindly help.
6 Replies 6
Marvin Rhoads
CCT has been retired. The current tool for building configurations is Cisco Commerce Workspace (CCW). Assuming you have the required partner level access, you can get to CCW and build estimates here:
https://apps.cisco.com/Commerce/home
Hope this helps.
Yes, I have access but when I goto the new option to be used instead of "create configuration" of "create estimate", I dont get options of adding SKU devices instead its showing preferences only.
Kindly suggest about what is to be done
If you cannot create an estimate (https://apps.cisco.com/ccw/cpc/estimate/create), there must be an issue with your profile. I just checked it and it's working fine for me.
Your company adminsitrator should be able to remedy profile issues. Alternatively, you can contact the CCW customer service team via phone or open a case online.
Click on the Help icon in CCW for details on how to do that:
Thanks. I will try that. Could you please send me the screen shot of what options you are getting when you enter "create estimate"
I am getting as below:
Sure - here is what I see when I select "Create New Estimate" (open in new tab to zoom):
Thanks! Have a great week ahead!!
