How can i connect an sdh to dwdm ncs 2006
tonyalex1986
Beginner
Beginner
Hi i have 4 locations where i want to plan a Dwdm network one being a hub and three locations more. At all the locations i have an SDH system for which i want to connect it to DWDM (*NCS 2006). what are the interfaces i need to consider in DWDM. Also i have a point to point link from hub to other 3 locations of size 4 x 10G and also an add-drop between all locations of size 10 x 1G. please help me to choose the DWDM equipment and its components. Please send some material so that i can understand the solutions.. Thank you..
kayukovvalera
Beginner
Beginner
To make DWDM Solution architects and disigners use Cisco Transport Planner (CTP) to make it accurately. CTP is licensed and it usually use Partners and Cisco SE. Please contact with your local Cisco CAM to make disign and BOM for you.
