09-02-2012 08:04 PM
I'm planning to upgrade our client's node an ONS 15454M12 from release 9.10 to release 9.221. Can i directly loadand upgrade it to release 9.221 or do I need to do step upgrade 9.10 to 9.211 then 9.221? Is it service affecting? ...many thanks.... cheers...
09-03-2012 03:19 AM
Hi Emyrsonn,
I hope this ONS 15454 upgrade tool can help you answering all your questions
http://www.cisco.com/web/techdoc/optical/15000r/upgrade/guide/ons-upgrade.html
It seems like you should be able to directly upgrade from 9.1.x to 9.2.2.
Please let me know if you have any comments on that.
Hope it helps!
09-03-2012 04:11 PM
Hi Ondrej,
thanks for the help... this is a great guide in the possible upgrades we will be doing in the Philippines... I'll update this discussion asap.. cheers...
09-03-2012 11:22 PM
You are very welcome, I am glad that it is helpful.
Cheers!
