Issue with cisco ONS 15310. Slot with Ethernet ports, designed for bridging.
vanessa-white
Hi, guys. I’ve got an issue with cisco ONS 15310 sdh optical network. I’ve got a special slot with Ethernet ports, designed for bridging. Assume, we’ve got to multiplexers, named A and B with ports A0 and B0 respectively. The ios console of these slots says, the configuration is as follows:
no ip address set on these ports
Ports are administratively up
Auto mdix
Bridge groups are the same on these ports.
Dot1q tunnel.
I’m trying to monitor a device with an ip-address connected to port B0. It answers ping if I connect the notebook directly to a device. But if I connect the notebook to port A0 and ping the device pluged in port B0 through the optical network, it doesn’t answer. I tried connections with straight and cross cable.
Guys, who set the network said, it should work as a point to point bridge with no extra configuration. But it doesn’t. I used wireshark sniffer to lookup what’s happening on port A0. All I see is cdp-s from port A0 and self-announcements of the notebook.
Any suggestions? Thank you in advance.
7 Replies 7
Marvin Rhoads
I'm assuming you are using ML-100T-8 cards - correct?
It sounds like you might possibly have an issue with the VLAN or dot1q tunneling setup. Have you had a look at the configuration guides for the card (here)?
Can you possibly post the IOS configuration from the ML-100T-8 cards at each end?
A
Current configuration : 3263 bytes
! Last configuration change at
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname A
boot-start-marker
boot-end-marker
enable password -
clock timezone -
ip subnet-zero
no ip routing
no ip domain-lookup
no mpls traffic-eng auto-bw timers frequency 0
bridge 13 protocol ieee
bridge 30 protocol ieee
bridge 40 protocol ieee
bridge 121 protocol ieee
bridge 122 protocol ieee
bridge 140 protocol ieee
bridge 141 protocol ieee
bridge 142 protocol ieee
bridge 143 protocol ieee
bridge 144 protocol ieee
interface FastEthernet0
description -
ip address x.x.x.x 255.255.255.0
no ip route-cache
mode dot1q-tunnel
bridge-group 140
bridge-group 140 spanning-disabled
interface FastEthernet1
description --- A0 ---
no ip address
no ip route-cache
mode dot1q-tunnel
bridge-group 141
bridge-group 141 spanning-disabled
interface FastEthernet2
description -
no ip address
no ip route-cache
mode dot1q-tunnel
bridge-group 142
bridge-group 142 spanning-disabled
interface FastEthernet3
description -
no ip address
no ip route-cache
mode dot1q-tunnel
bridge-group 143
bridge-group 143 spanning-disabled
interface FastEthernet4
description -
no ip address
no ip route-cache
mode dot1q-tunnel
bridge-group 144
bridge-group 144 spanning-disabled
interface FastEthernet5
description -
no ip address
no ip route-cache
mode dot1q-tunnel
bridge-group 121
bridge-group 121 spanning-disabled
interface FastEthernet6
description -
no ip address
no ip route-cache
mode dot1q-tunnel
bridge-group 122
bridge-group 122 spanning-disabled
interface FastEthernet7
description -
no ip address
no ip route-cache
mode dot1q-tunnel
bridge-group 13
bridge-group 13 spanning-disabled
interface POS0
description -
no ip address
no ip route-cache
crc 32
interface POS0.1
encapsulation dot1Q 141
no ip route-cache
no snmp trap link-status
bridge-group 141
interface POS0.2
encapsulation dot1Q 142
no ip route-cache
bridge-group 142
interface POS0.3
encapsulation dot1Q 143
no ip route-cache
bridge-group 143
interface POS0.4
encapsulation dot1Q 144
no ip route-cache
bridge-group 144
interface POS0.5
description -
encapsulation dot1Q 140
no ip route-cache
bridge-group 140
interface POS1
description -
no ip address
no ip route-cache
crc 32
interface POS1.1
encapsulation dot1Q 121
no ip route-cache
bridge-group 121
interface POS1.2
encapsulation dot1Q 122
no ip route-cache
bridge-group 122
interface POS1.3
description -
encapsulation dot1Q 13
no ip route-cache
bridge-group 13
ip classless
no ip http server
control-plane
line con 0
line vty 0 4
password -
login
end
B
Building configuration...
Current configuration : 3712 bytes
version 12.2
no service pad
hostname B
boot-start-marker
boot-end-marker
enable password -
clock timezone -
ip subnet-zero
no ip domain-lookup
bridge 100 protocol ieee
interface Loopback0
ip address 192.x.0.x 255.255.255.255
description -
no ip address
mode dot1q-tunnel
bridge-group 140
description --- B0 ---
no ip address
mode dot1q-tunnel
bridge-group 141
description -
no ip address
mode dot1q-tunnel
bridge-group 142
description -
no ip address
mode dot1q-tunnel
bridge-group 143
description -
no ip address
mode dot1q-tunnel
bridge-group 144
no ip address
shutdown
no ip address
shutdown
description -
no ip address
shutdown
mode dot1q-tunnel
bridge-group 100
bridge-group 100 spanning-disabled
interface POS0
description -
no ip address
crc 32
interface POS0.1
bridge-group 141
interface POS0.2
bridge-group 142
interface POS0.3
bridge-group 143
interface POS0.4
bridge-group 144
interface POS0.5
description -
bridge-group 140
interface POS1
no ip address
crc 32
interface POS1.1
encapsulation dot1Q 100
bridge-group 100
router ospf 100
log-adjacency-changes
network 192.x.0.x 0.0.0.0 area 0
ip default-gateway [x.x.x.x]
ip classless
no ip http server
snmp-server community public RO
snmp-server ifindex persist
snmp-server trap link ietf
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps config
snmp-server enable traps cpu threshold
snmp-server enable traps entity
snmp-server enable traps syslog
snmp-server enable traps hsrp
snmp-server enable traps config-copy
snmp-server enable traps bridge
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps bgp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps ipmulticast
snmp-server enable traps rtr
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls ldp
snmp-server enable traps rsvp
snmp-server enable traps l2tun session
snmp-server enable traps mpls vpn
snmp-server host x.x.x.x public
control-plane
line con 0
line vty 0 4
password -
logging synchronous level 4
login
end
Yes.
Can’t access the page.
Yes.
I use interfaces FastEthernet1 on both sides.
Today I tried "no mode dot1q-tunnel" on these interfaces. Didn't help.
Sorry about the bad link - you should be able to use this customer link for the ML-100T-8 card:
http://www.cisco.com/en/US/customer/docs/optical/15000r9_1/ethernet/310/guide/31091_ether.html
Hmmm. I was going to suggest what you already tried - "no mode dot1q tunnel".
Having that mode on means the Ethernet interfaces on the ML-100T-8 are expecting your traffic to enter with VLAN tags. Please have a look at this guide:
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/dot1qtnl.html
(The link is for a 7600 router guide but the concepts are applicable to IOS in general.)
You should make sure that you are tagging your traffic towards the ONS at both ends (that is, you are set up as a trunk port and using dot1q encapsulation: "switchport mode trunk" and "switchport trunk encapsulation dot1q" commands on your switches at each end) and that you are forcing the port towards the ONS to be in spanning tree forwarding mode ("spanning-tree portfast trunk" command).
Your advices were very very very very helpful! It looks more clear now.
Thanks! Thanks for helping me, I really appreciate such a support.
You're welcome.
Please rate posts if they help.
