05-15-2017 03:15 PM
Hi, im Victor and im having two problems in a switch, from one side i have a switch A te2/0/2 connected to a Switch B te2/0/2, the switch sometimes blink orange Green, and sometimes is blinking Green only. If the port ar runing a few hours, it suddenly stops to work and inthe side B the port goes to err-disabled.
Both switch are cisco 2960x and are running 15.2(2)E3, the fiberoptic are about 500 ft of lenght, with Belden Patchcord FT4 of 9.8ft with gbix SFP-10G-SR.
Switch A
TenGigabitEthernet2/0/2 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is 188b.459f.5eb4 (bia 188b.459f.
Description: Redundant Link to SSRAMSWAL003 Te2/0/2
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
reliability 253/255, txload 1/255, rxload 1/255
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
input flow-control is off, output flow-control is unsupported
Last input 00:00:36, output 00:00:36, output hang never
Last clearing of "show interface" counters 00:00:48
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 764000 bits/sec, 206 packets/sec
5 minute output rate 771000 bits/sec, 150 packets/sec
2033 packets input, 463456 bytes, 0 no buffer
Received 2033 broadcasts (2013 multicasts)
16 input errors, 16 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 2013 multicast, 0 pause input
12 packets output, 2394 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Transmit TenGigabitEthernet2/0/2 Receive
186323203 Bytes 764462964 Bytes
315288 Unicast frames 354224 Unicast frames
159743 Multicast frames 5335490 Multicast frames
9315 Broadcast frames 119874 Broadcast frames
0 Too old frames 164649252 Unicast bytes
0 Deferred frames 514993140 Multicast bytes
0 MTU exceeded frames 9131237 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 159916 FCS errors
0 3 collision frames 49 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 13608 Collision fragments
0 6 collision frames
0 7 collision frames 273999 Minimum size frames
0 8 collision frames 4631703 65 to 127 byte frames
0 9 collision frames 647898 128 to 255 byte frames
0 10 collision frames 325866 256 to 511 byte frames
0 11 collision frames 23344 512 to 1023 byte frames
0 12 collision frames 53486 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 15756 Symbol error frames
0 Late collisions 9074 Invalid frames, too large
0 VLAN discard frames 33547 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
11050 64 byte frames 0 Valid frames, too small
169464 127 byte frames
145060 255 byte frames 0 Too old frames
69376 511 byte frames 0 Valid oversize frames
16653 1023 byte frames 0 System FCS error frames
34651 1518 byte frames 0 RxPortFifoFull drop frame
38092 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
Switch B
Hardware is Ten Gigabit Ethernet, address is 188b.459f.3434 (bia 188b.459f.3434)
Description: Redundant Link to SSRAMSWAL002 Te2/0/2
Keepalive not set
Last input 00:00:25, output 00:00:24, output hang never
Last clearing of "show interface" counters 00:01:09
5 minute input rate 656000 bits/sec, 120 packets/sec
5 minute output rate 651000 bits/sec, 176 packets/sec
26 packets input, 4002 bytes, 0 no buffer
Received 26 broadcasts (26 multicasts)
0 watchdog, 26 multicast, 0 pause input
2077 packets output, 386346 bytes, 0 underruns
764882246 Bytes 186223887 Bytes
388824 Unicast frames 315211 Unicast frames
5494161 Multicast frames 159439 Multicast frames
122655 Broadcast frames 9314 Broadcast frames
0 Too old frames 158446772 Unicast bytes
0 Deferred frames 25573574 Multicast bytes
0 MTU exceeded frames 744441 Broadcast bytes
0 2 collision frames 0 FCS errors
0 3 collision frames 0 Oversize frames
0 5 collision frames 0 Collision fragments
0 7 collision frames 11008 Minimum size frames
0 8 collision frames 169365 65 to 127 byte frames
0 9 collision frames 144890 128 to 255 byte frames
0 10 collision frames 69353 256 to 511 byte frames
0 11 collision frames 16628 512 to 1023 byte frames
0 12 collision frames 34629 1024 to 1518 byte frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 38091 Valid frames, too large
275432 64 byte frames 0 Valid frames, too small
4637854 127 byte frames
646526 255 byte frames 0 Too old frames
326145 511 byte frames 0 Valid oversize frames
23272 1023 byte frames 0 System FCS error frames
53675 1518 byte frames 0 RxPortFifoFull drop frame
42736 Too large frames
Can you help me to check if someting is wrong? or if i need to configure anything else on the interface? both are wi this configuration:
interface TenGigabitEthernet2/0/2
description Redundant Link to SSRAMSWAL003 Te2/0/2
switchport mode trunk
By other side, i have the switch A connected to my core switch and the same situation, are not working OK, the weird thing is that was working ok and that the B switch has the same configuration and versions and are connected to the same switch and are working OK.
This is the info for this interface gi1/0/49 from A switch, note, i just reset it about a 20 minutes ago.....
GigabitEthernet1/0/49 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 188b.459f.4431 (bia 188b.459f.4431)
Description: Uplink to SSRAMSWDL001 Gi1/1/2
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
Last input 00:00:00, output 00:00:02, output hang never
Last clearing of "show interface" counters 00:28:02
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1737
5 minute input rate 1836000 bits/sec, 429 packets/sec
5 minute output rate 2543000 bits/sec, 468 packets/sec
934193 packets input, 571468598 bytes, 0 no buffer
Received 48381 broadcasts (39979 multicasts)
0 watchdog, 39979 multicast, 0 pause input
934948 packets output, 574308328 bytes, 0 underruns
sh controllers ethernet-controller gi1/0/49
Transmit GigabitEthernet1/0/49 Receive
3009633492 Bytes 1047667804 Bytes
1918782770 Unicast frames 1833288838 Unicast frames
10382137 Multicast frames 306482603 Multicast frames
2027031 Broadcast frames 141170395 Broadcast frames
0 Too old frames 1177069505 Unicast bytes
0 Deferred frames 3411007577 Multicast bytes
0 MTU exceeded frames 1950148513 Broadcast bytes
0 2 collision frames 1197 FCS errors
0 5 collision frames 399 Collision fragments
0 7 collision frames 72053411 Minimum size frames
0 8 collision frames 824615649 65 to 127 byte frames
0 9 collision frames 419220019 128 to 255 byte frames
0 10 collision frames 285244496 256 to 511 byte frames
0 11 collision frames 42967605 512 to 1023 byte frames
0 12 collision frames 437914162 1024 to 1518 byte frames
0 Excessive collisions 1185643 Symbol error frames
0 Late collisions 182679 Invalid frames, too large
0 VLAN discard frames 199930494 Valid frames, too large
0 Excess defer frames 560 Invalid frames, too small
1107759 64 byte frames 0 Valid frames, too small
454740674 127 byte frames
431180245 255 byte frames 0 Too old frames
267725729 511 byte frames 0 Valid oversize frames
51891002 1023 byte frames 0 System FCS error frames
132042261 1518 byte frames 0 RxPortFifoFull drop frame
592504268 Too large frames
can you help me please? thanks!!
Solved! Go to Solution.
05-15-2017 03:50 PM
159916 FCS errors
Be very careful about clearing interface counters because it wipes away critical evidences. I am very happy to see that not everyone knows how to clear the counters for the "sh controller e" command because it shows me it's a Layer 1 issue.
This snapshot tells me that there is a potential Layer 1 issue with Ten 2/0/2.
05-15-2017 03:50 PM
159916 FCS errors
05-16-2017 07:18 AM
Hi Leo Laohoo, it seems that everything its ok after i changed the fiber to other pair about an hour ago.... thanks for your help! ill keep this thread updated, best regards!
