Link Loss budget - Max SFP distance? Max TX vs Min TX?
james
Beginner
Beginner
People say you should use the MinTX when calculating loss budget, if so, what is the Max TX used for?
The QSFP-40G-ER4 has a MaxTX of 4.5, but a MinTX of -2.7.
Can I use the MaxTX of 4.5 & MaxRX of -21.2 to create a loss budget of -25.7? or is this breaking the rules?
Tom Randstrom
When designing an optical link, you want to make sure that it is operational across the entire operating characteristics of the specified transceiver; which allows you to swap a failed module (or similar type) and know that the link will be operational.  If you were to use the Max-TX in your initial calculations, and a replacement transceiver was operating at closer to the Min-Tx specification, your Min-Rx value would fall outside the operating range; resulting in possible bit errors and outage.  Also, transceiver output powers can vary during the lifetime of the product.
