cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Low receive power on optical interfaces; troubleshooting remotely
esa_fresa
I have a switch with all four 10g optical links on a port channel showing -40.0 dBm Optical Receive Power. I believe this means it's not receiving a signal at all. I don't have physical access to the switch nor the device the port channel is connecting to. I'll have physical access tomorrow, but is there anything I can do today to troubleshoot the issue?
Anything at all would be helpful, thanks in advance !
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Marvin Rhoads
You're right. -40.0 dBm indicates no light is being received. It's either a physical layer problem or the interfaces are shutdown at the distant end.
There's not anything you can do without access to verify one or both of those factors.
Ver la solución en mensaje original publicado
2 RESPUESTAS 2
Marvin Rhoads
Rats, I was hoping that wasn't the case. Thanks Marvin.
