03-25-2015 01:15 PM
We just updated to windows 7 pro 32 bit and now we can not communicate with the ONS 15454.
It worked fine with XP but now all it does when you run CTC is just sit there and give you no log in.
Solved! Go to Solution.
03-26-2015 07:06 AM
Hi phill00011,
Windows 7 requires autotuning to be disabled in order to run CTC. Please see below for instructions.
http://www.cisco.com/en/US/docs/optical/15000r9_2/dwdm/procedure/guide/454d92_ctcoperation.html#wp204480
Complete the following steps to Disable TCP Autotuning:
a. From the Windows Start menu, click Search > Search for Files and Folders. The Search window appears.
b. On the right side of the window in the Search box, type Command Prompt and press Enter. Windows will search for the Command Prompt application and list it in the search results.
c. Right click cmd and select Run as administrator.
d. Enter the administrator user ID and password and click OK.
e. A Command prompt windows appears. At the command prompt enter the following text:
netsh interface tcp set global autotuninglevel=disabled
Autotuning can be enabled if desired using the following command:
netsh interface tcp set global autotuninglevel=normal
shows status of autotuning
netsh interface tcp show global
Ryan
03-26-2015 07:06 AM
Hi phill00011,
Ryan
03-26-2015 11:20 AM
Thanks Ryan works great. phill00011
