01-19-2016 07:33 PM
Our customer needs to know the CPU utilization of their ONS15154 M12. They need to retrieve period CPU utilization darta..
Anyone have done this? Greatly appreciate your answers...
Thanks in advance..
Solved! Go to Solution.
02-12-2016 09:28 AM
Firstly I would like to note that there are no any need to monitor it because there are no any cases regarding high CPU utilization. If you will check Troubleshooting guide you will see that there are no any alarm about Hight CPU.
Secondly there are no any SNMP traps available to do that.
Thirdly there are only one way to check it with use of vxworks commands by telnet session. BUT use of special VxWorks commands supported and use only by TAC and BU teams. If you will use it they can deny your requests for help because of violation of product use. TAC can use this command:
vclDumpHistory
to check what did you tried to perform in ONS\NCS node.
BUT if you steal want to do that you have use this command:
spy
Output example:
spy
NAME ENTRY TID PRI total % (ticks) delta % (ticks)
tJobTask 0x10098410 0x103eeb00 0 0% ( 0) 0% ( 0)
tExcTask 0x10097880 0x101d6560 0 0% ( 0) 0% ( 0)
One tick in ONS\NCS:
1 tick = 500seconds
Be very carefully when use VxWorks commands!!!
02-12-2016 09:28 AM
vclDumpHistory
spy
Output example:
spy
1 tick = 500seconds
