ONS15454 Subtended Shelf VLAN
chris-hart
Hi Does anyone know if you can configure the subtended shelf in a muli-shelf configuration into a VLAN other than the default VLAN 2.
Chris
2 Accepted Solutions
Tom Randstrom
I don't know the answer but the following Cisco discussion might provide some insight.
https://supportforums.cisco.com/thread/2055162?tstart=30
mayfwh
Chris,
Starting in 9.1, you are able to select the private VLAN.
Here is the relevant 9.1 documentation:
Procedure Guide Chapter 1:
http://www.cisco.com/en/US/docs/optical/15000r9_1/dwdm/procedure/guide/454d91_installshelf.html
NTP-G159 Configure a Cisco Catalyst 2950 for a Multishelf Node
or
NTP-G294 Configure the MS-ISC-100T Card for a Multishelf Node for Non-Default Public and Private VLAN IDs
Procedure Guide Chapter 2:
http://www.cisco.com/en/US/docs/optical/15000r9_1/dwdm/procedure/guide/454d91_turnupnode.html
NTP-G144 Provision a Multishelf Node
Will
Tom Randstrom
mayfwh
Chris,
or
Will
Thanks guys, I knew I thought I'd seen it somewhere, just couldn't remember where.  As an aside I actually requested this functionality over 2 years ago so I may in some small way have been instrumental in the enhancement.
Thanks again
Chris
