Open V-Cat in CTM 8.5
Stephen King
What version CTM, if any, will support open V-cat circuit provisioning?
mayfwh
Open VCAT circuits are possible starting in CTM 9.0.
The procedure is in the CTM 9.0 User's Guide, Chapter 7:
7.2.4.2  Creating a Regular or Open-Ended VCAT Circuit
http://www.cisco.com/en/US/docs/net_mgmt/cisco_transport_manager/9.0/user/guide/90servpr.html#wp1600580
To navigate, first open the User Guide, then click on the link for Chapter 7, then select the link for "7.2.4  Creating Circuits Using the Circuit Wizard" and lastly, scroll down to the link for the procedure for creating a VCAT circuit.
Hope this helps.
Will
mayfwh
Hope this helps.
Will
Thanks Will,
More fodder to get  them to purchase 9.0..
