Point to Point, outdoor, line of site, wireless network
jackremboldt
I posted this in the wireless area as well, but didn't get a solution.
I'm looking for a device to (securely) connect two buildings together that are across the street from one another. The distance is 500 feet at most, and there is a direct line of site. It would cost too much to tunnel under the street, so I'm looking for an alternative. This is also a disaster recovery connection, in the event the fiber was cut. I'd like to go Gig over it, but basic backup connectivity is the requirement.
Does Cisco have a product or partner with anyone?
Jack
5 Replies 5
jamesketner
Jack,
You have a couple of options. Cisco Airespace will work for the distance,but trying to achive a gigabit is going to be tough. There is a company called Lightepoint that Cisco has funded heavily in, but I believe they are only at a OC3 level. Security will fall under the configurations that you set forth in the configurations. If you are just looking for basic connecitivity I would recommend the airespace.
konigl
Level 7
Level 7
Sounds like what you are looking for is free space optics (FSO). Typically comes into play when underground boring and running your own fiber through conduit is cost-prohibitive; leasing dark fiber is not an option; wireless is considered either too slow, or not secure enough; and you can see where you want to connect.
Cisco doesn't have anything in this niche, as far as I know; but if you do a Google.com search on "free space optics" you will find a ton of information.
Think of FSO as big media converters. Connect one to a Gigabit Ethernet port on your Cisco switch or router, it will transmit point-to-point through the air to another unit at the remote site.
Biggest downside to FSO is they are vulnerable to weather degradation. Think fog: if you can't see the other building, neither can your FSO solution. Some vendors offer a hybrid solution, combining optics and radio frequency wireless, to get around this issue.
Searching Cisco's web site brings up a couple of hits for LightPointe (www.lightpointe.com). And paging through a recent issue of Network World magazine, Canon's got something they call Canobeam (www.canobeam.com). If you want Gigabit Ethernet, look for the models that mention a signaling rate of 1.25 Gbps.
rangakishore
Hi,jackremboldt
My sugesstion for your requirement is better you choose wireless PTP connectivity using with Cisco aironet wireless products (AIR-BR1310-A-K9) wireless bridging connectivity. the product is supports 54Mbps standard of IEEE 802.11a/g.
Compare to FSO Cisco aironet wireless bridging connectivity is match your requirement.
Ranga Kishore
scottmac
Level 10
Level 10
Check out Canon CannoBeam. Same guys as the camera outfit.
They have GigE optical that's good for up to a mile (2000 meters).
For a 500 foot span, it'd take some pretty seriously wicked weather to degrade the connection.
Here's a link:
http://www.usa.canon.com/html/industrial_canobeam/canobeam/canobeam100.html
Good Luck
Scott
tim.devries
We use (as another poster pointed out) the lightpointe flightstrat 1.2G product to connect two buildings about 1KM from each other. The four rotating lasers in the unit ensure that weather is not a problem. The capacity is 1.2G.
