Pre-Upgrade check failed. Insufficient free space in /var/tmp. Less than required 90%
eefranzen
I'm going through the process to update the firmware on several 6296 Fiber Interconnects. They are currently at version 2.2(3c) and we are going to 2.2(5a).
The upgrade process fails at step 14, waiting for activation to finish and when I look at the Fiber Connect, the error shows:
Code F78093 Pre-Upgrade check failed. Insufficient free space in /var/tmp. Less than required 90%.
We wait the hour for the step to timeout and then reboot the FI and then Auto-Deploy finished that one and then goes to the next one, where it fails with the same error.
I'm on my 6th POD and all are showing this error.
2 questions,
one, how can I prevent this?
two, how can I cancel the step so I don't have to sit and wait the hour for it to timeout? I have tried rebooting before the step times out, but the tasks never retries.
Thanks in advance
rosaho
Level 3
Level 3
This discussion has been reposted from Additional Communities to the Optical Networking community.
