Dmitriy Pavlov
Beginner
Problems with Cisco ONS 15305
I've got a problem with my Cisco ONS 15305. When started, it reboots, and the following message shows up:
BOOTSTRAP SW V2.0  Date  18-Mar-2003  Time  16:33:44
BUS test started.
BUS test SUCCESS !
REASON FOR BOOT IS: SOFTWARE WATCHDOG RESET
THE INTERRUPTED ADDRESS WAS: 0x0
Continue Bootstrap process...
Read Application from Compact Flash...
Decompressing SW ...
64c000OK
Boot Complete: Starting Application Sw...
Self-test started. Please wait ...
HOSTG_compact_flash_test: Compact flash internal diagnostics started!
HOSTG_compact_flash_test: Compact flash drive identification started!
Crossbar Test...
Crossbar Ok.
FE Switch: Slot: 3, Type: 27, Floor: 1
FE Switch Register Access Test (BlockFetch DMA)...
FE Switch Register Access test Ok.
Switch Control SDRAM bus test.
Switch Control SDRAM bus test Ok.
Switch Data SDRAM bus test.
Switch Data SDRAM bus test Ok.
FE Switch: Slot: 3, Type: 27, Floor: 2
Galnet tests OK.
Self-test results:
TEST SEGMENT   RESULT(0=OK,1=NOK)      ERRORCODES(All F's=NOT RUN)
BUS_TEST_1             0               0       0
BUS_TEST_2             0               0       0
SDRAM_TEST_1           0               ffffffff        ffffffff
SDRAM_TEST_2           0               ffffffff        ffffffff
BOOT_FLASH_TEST        0               0       0
COMPACT_FLASH_TEST     0               0       0
NVRAM_TEST             0               0       0
RTC_TEST               0               0       0
GALNET_TEST            0               0       0
CF manufactorer info: SanDisk SDP 5/3 0.6
Size In Mb: 32.
Heads: 4.
Cylinders: 490.
Sectors: 62720.
HOSTC_flash_init Info: The following NR files are present:
- 55004-01BB, Ics 06
- 45004-70AA, Ics 06
- 45004-72AA, Ics 08
- 45004-73AA, Ics 03
- 45004-73AB, Ics 04
- 45004-74AA, Ics 06
- 45004-74AB, Ics 01
- 45004-76AA, Ics 04
- 45004-77BB, Ics 06
- 45004-80AA, Ics 02
- 45004-81AA, Ics 04
- 45004-82AB, Ics 04
- 45004-83AA, Ics 03
- 45004-84AA, Ics 03
- 45004-85AA, Ics 06
- 45004-87AA, Ics 07
- 45004-88AA, Ics 03
- 45004-89AA, Ics 02
- 45004-90AA, Ics 06
- 45004-90AB, Ics 05
- 45004-91AA, Ics 06
- 45004-91AB, Ics 05
- 45004-92AA, Ics 01
- 45004-93AA, Ics 03
- 45016-01BA, Ics 04
---  RUNNING SW REVISION - R3.0.0
---  Date 03-Feb-2006 Time 14:57:18
Base Mac address is: 00:04:7a:0c:5f:f0
HOSTG_start: Start Ros...
Exception 200 at IP 3ab554
The ONS reloads again and again.....
Could you please help me resove the problem?
Thank you.
2 REPLIES 2
Glenn Matthys
Beginner
FYI, a watchdog is a software or hardware mechanism that, when it doesn't receive a certain signal for a certain time, will carry out some kind of action. In this case the OS is not reporting it's "OK" (because it crashed -
Exception 200 at IP 3ab554), which makes the watchdog reset the device.
A few things to check:
* Is the device's RAM OK? Faulty RAM leads to crashes
* CF manufactorer info: SanDisk SDP 5/3 0.6
Is that an official Cisco CF card? Try replacing it with another
Software is old, are there any updates available?
kayukovvalera
Beginner
- recomend upgrade to 3.0.7
- backup configuration, default factory reset, upload config
If you would like, we could make webex. my e-mail  v_kayukov@step.ru
