03-18-2019 12:49 PM
I'm changing my old D-Link DGS-3120-48TC switch to Cisco SG300-52P switch and the only thing I'm not sure are SFP ports. Is there any way to check if my old SFP d-link modules will be fine for Cisco SFP ports? Are there any differences between them and will it work with other D-Link switches? Eventually, I will change them too, just not in one shot. With one brand it was easy to choose and I didn't have to learn more about, so I'm not sure if there is a standard and all ports are the same and all SFP modules will work fine, or I have to buy specific modules for specific switch brand.
Thank you in advance for your answers!
Solved! Go to Solution.
03-18-2019 02:53 PM - edited 03-18-2019 03:15 PM
Not sure about the SG series, but most Cisco Enterprise network devices, by default, will only work with Cisco SFP modules (which are often specific to a device with a certain IOS level). There is a hidden command, on many Cisco Enterprise devices, to allow them to work with non-Cisco modules, and they often will, but sometimes they don't and if you have issues, Cisco will not support trying to get them to work.
You can try them though, and if they work consider yourself lucky. It also helps if the non-Cisco vendor guarantees they will work with Cisco equipment.
03-18-2019 03:14 PM
03-18-2019 03:27 PM
