SFP ERROR WITH ASR901
hello team,
we have sfp GLC-LH-SMD (original transceiver)
but I can't get that link.
the optical fiber is correct. do you have to do some special command?
help please
how interfaces gigabitEthernet 0/5 transceiver
Transceiver monitoring is disabled for all interfaces.
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
Optical Optical
Temperature Voltage Current Tx Power Rx Power
Port (Celsius) (Volts) (mA) (dBm) (dBm)
Gi0/5 40.4 3.30 15.6 -7.1 -6.5
7 Replies 7
balaji.bandi
Try "no negotiation auto" on the interface config
Still having an issue, please tell us what is other side device and also post
show run interface g 0/5
show inter gi 0/5
BB
yes, the same!
no multicast routing
doesn´t recognize original sfp.
show inter gi 0/5
GigabitEthernet0/5 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 881d.fc01.3799 (bia 881d.fc01.3799)
MTU 9216 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full Duplex, 1000Mbps, link type is auto, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/200/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Building configuration...
Current configuration : 144 bytes
interface GigabitEthernet0/5
no ip address
negotiation auto
service instance 8 ethernet
encapsulation untagged
bridge-domain 8
end
show interfaces status
Port Name Status Vlan Duplex Speed Type
Gi0/0 notconnect 1 auto auto GigabitEthernet0/0
Gi0/1 notconnect 1 auto auto GigabitEthernet0/1
Gi0/2 notconnect 1 auto auto GigabitEthernet0/2
Gi0/3 notconnect 1 auto auto GigabitEthernet0/3
Gi0/4 notconnect 1 auto auto GigabitEthernet0/4
Gi0/5 notconnect 1 auto auto GigabitEthernet0/5
Gi0/6 notconnect 1 auto auto GigabitEthernet0/6
Gi0/7 notconnect 1 auto auto GigabitEthernet0/7
Gi0/8 disabled 1 auto auto GigabitEthernet0/8
Gi0/9 disabled 1 auto auto GigabitEthernet0/9
Gi0/10 disabled 1 auto auto GigabitEthernet0/10
Gi0/11 disabled 1 auto auto GigabitEthernet0/11
show interfaces gigabitEthernet 0/5 transceiver
Optical Optical
Gi0/5 43.8 3.22 19.6 -1.4 -6.7
this error with other interfaces.
R1(config)#interface GigabitEthernet0/9
R1(config-if)#no shutdown
Jan 11 02:44:12.369: %LICENSE-1-REQUEST_FAILED: License request for feature Gige4SfpUpgrade 1.0 failed. UDI=A901-4C-FT-D:CAT1839U1KT
balaji.bandi
I am confused here?
original post you mentioned? sfp GLC-LH-SMD (original transceiver)
as per the error you have License issue :
Can you post
show version and shw license all.
here is the reference guide and requirement :
https://www.cisco.com/c/en/us/td/docs/wireless/asr_901/Configuration/Guide/b_asr901-scg/b_asr901-scg_chapter_0101.html#con_1089389
BB
yes, we have 3 router!
Link is fiber!
but it doesn’t recognize sfp in any of the 3
show version
Cisco IOS Software, 901 Software (ASR901-UNIVERSALK9-M), Version 15.3(2)S2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 12-Aug-13 05:10 by prod_rel_team
ROM: System Bootstrap, Version 15.4(1r)S2, RELEASE SOFTWARE (fc1)
PIM-SPARSE-MODE-OSPF-1 uptime is 18 hours, 51 minutes
System returned to ROM by reload at 01:20:58 UTC Tue Sep 30 2014
System restarted at 00:01:34 UTC Sat Jan 1 2000
System image file is "flash:asr901-universalk9-mz.153-2.S2.bin"
Last reload type: Normal Reload
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: AdvancedMetroIPAccess
License Type: Permanent
Next reload license Level: AdvancedMetroIPAccess
Cisco A901-4C-FT-D (P2020) processor (revision 1.0) with 393216K/131072K bytes of memory.
Processor board ID CAT1839U1KT
P2020 CPU at 800MHz, E500v2 core, 512KB L2 Cache
1 FastEthernet interface
12 Gigabit Ethernet interfaces
1 terminal line
256K bytes of non-volatile configuration memory.
98304K bytes of processor board System flash (Read/Write)
you have "License Level: AdvancedMetroIPAccess"
The below document explains to you what license you need. also, explain the error you see, so contact partner get feature license,
Port Based License
Try :
Combo ports are either copper or SFP ports depending on the configuration specified in the media-type command.
BB
do you think this may be the problem with sfp, multicast?
I'm going to test because the media-type command doesn't recognize it.
balaji.bandi
Your license have an issue you need to upgrade.
BB
