SFP+ uplink connectivity
edwincharles
hi,
i need help in uplink connectivity
if SFP+ connected at 3750-x and want to connect to 6500 filber module with X2, will it work
will it communicate between SFP+ and X2
should it be same at both ends
2 Accepted Solutions
stefanhoppe
ethernet alliance had tested all kinds of interoperability. And find out, that in general it should work:
http://www.ethernetalliance.org/files/static_page_files/83B8AACC-C299-B906-801EE945307E8BDD/SFP+%20Interoperability%20Demonstration.pdf
Have a look at "Test 3"
Leo Laohoo
Yes as long as they are the same "mode", i.  e.  both ends are multi-mode or single-mode and not single-mode in one end  and multi-mode in another end.
stefanhoppe
Leo Laohoo
