TCC2P MEM-LOW
d.keeley
Why would TCC2P cards running 8.0.0 not have enough memory? We have a dozen or so circuits on a standard ring design. The Node reporting the alarm is a repeat site only. I haven't contacted TAC but I suspect they'll suggest a swact on the reporting shelf...
Thanks.
6 Replies 6
Tom Randstrom
This would not seem to be standard operation.
Per the Troubleshooting Guide:
MEM-LOW
Default Severity: Minor (MN), Non-Service-Affecting (NSA)
Logical Object: EQPT
The Free Memory of Card Almost Gone alarm occurs when data generated by software operations is close to exceeding the memory capacity of the TCC2/TCC2P card. The alarm clears when additional memory becomes available. If additional memory is not made available and the memory capacity of the card is exceeded, CTC ceases to function.
The alarm does not require user intervention. If the alarm does not clear, log into the Technical Support Website at http://www.cisco.com/techsupport for more information or call Cisco TAC (1 800 553-2447).
Ya, read the same thing. It doesn't say much other than the obvious. Guess I'm hoping someone has experience with the root of the problem.
tgimmel
Do you have a large network or somehow have let it learn lots of routes? When the TCC2 get about 600 routes are so it hits the 50% memory alarm.
Tim
This DWDM ring has 14 NE's, add another 6 or so for transponder shelves. The routing table on the reporting shelf currently shows 23 routes but the alarm has cleared. I'll check the routing table next time the alarm appears. Thanks for the info.
tsim496
I've found that if you're monitoring the chassis for performance statistics via SNMP, there tends to be a memory leak/exhaustion issue.
This can be followed by free running sync and TCC resets. In an extreme instance, I have seen a two side 6 node multishelf MSTP network reset several times per month. The only resolution was an upgrade to 8.51, which I was told contained enhanced memory management, and the omission of placeholders/support for older line cards.
Well we don't monitor via SNMP as well we don't time any of the MSTP boxes which should rule out the free run sync issue. I don't believe I've seen TCC resets as a result of the MEM-LOW issue, other than those I've done myself to clear the alarm.
As for the upgrade to 8.5.1, as a result of the 2 degree 6 node multishelf resets, that's a direction I'm about to take.
Thanks for the info, very helpful
