08-19-2021 12:32 AM
Currently I have a SW Cisco Catalyst 2960X-48FPS-L, which has SFP Gbics and a fiber of 10 GB to connect from this SW to another Cisco Catalyst 2960X-48FPD-L which supports SFP+ 10 GB.
Could you help on choose the right tranceiver to uplink 1 GB to 10 GB in the Cisco Catalyst 2960X-48FPS-L ?
Or Do I need just to verify if programming the SW 48FPS-L, I can uplink current SFP to support SFP+?
Please confirm if possible.
Thank you.
08-19-2021 01:09 AM
Cisco optics support same speed and same wavelengths at both ends.
So if one side is SFP, the other side must be identical.
08-19-2021 01:57 AM
There is no way you can connected different speeds,
Both side should be same Like 1GB SFP to 1GBSFP same wavelenth or 10GB SFP to 10GB SFP same wave length ,
08-26-2021 10:44 AM
You could install a 1 Gbps transceiver in the 2960X-48FPD-L per the below compatibility matrix.
https://tmgmatrix.cisco.com/?si=2960X-48FPD-L
Otherwise, you will have to change out the 2960X-48FPS-L to a switch that supports a 10Gbps transciever.
