05-29-2015 12:21 AM
Dear All,
Is there any requirement to reload the card when changing from LAN PHY to WAN PHY?
ASR 9001
A9K-MPA-4X10GE
Regards, Pok.
Solved! Go to Solution.
05-29-2015 12:42 AM
On 7600, definetly not. but not sure on asr9k
05-29-2015 02:16 AM
If its STM64 then 99% it wil be in WANPHY mode or ONT mode, but need to identify the actual operating mode on it, bcos if its in ONT then need to change the mode on router side as well. Also verify the SFPs at both ends, its should be OC192LR
05-29-2015 12:42 AM
05-29-2015 12:53 AM
Hi Vivek,
Can you advise and step to configure WAN PHY,
In Cisco Doc I found only two commands
interface tenGi0/0/1/1
transport-mode wan
controller wanphy 0/0/1/1
wanmode on
after that I saw the port not up.
Regards, Pok.
05-29-2015 01:49 AM
On 7600, we didn't add "wanmode on" under controller. Rest config is same.
Can you also check on the other end, how its configured ?
05-29-2015 01:54 AM
I have try with the guideline but seem no hope.
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/interfaces/command/reference/b_interfaces_cr43xasr9k/b_interfaces_cr43xasr9k_chapter_010100.html
Regards, Pok.
05-29-2015 02:00 AM
Ok, so it shows your configuration is correct. But have you verified the other end config ? is other end operating in same WANPHY mode or ONT mode or LAN PHY??
05-29-2015 02:07 AM
We are connecting to our MUX stm64 and the mapping is stm64c. The port on the router receive signal as normal but won't come up both are down/down.
05-29-2015 02:16 AM
05-29-2015 05:09 AM
It is working now the problem is our MUX.
Thank you very much for your advise.
Regards, Pok.
