WS-C3850: Transceiver for Single Mode Fiber?
JSAT1
Beginner
Beginner
My knowledge on switches is non existent. Please bear with me.
Problem: We have an existing Single mode fiber connected at the facility,
and are adding the C3850-24S-E switches as core switches and 3650s as distribution switches.
What Transceiver should I use? (we do not want to use media converters)
Will the GLC-LH-SMD work?
thank you!
Leo Laohoo
GLC-LH-SMD is supported.
What firmware is the switch stack running on?
WS-C3850-24S-03.06.05E
(cat3k_caa-universalk9.SPA.03.06.05.E.152-2.E5.bin)
I see GLC-LH-SMD is compatible on/after XE 3.3.3SE, 16.1.1 XE 3.3.3SE, 16.1.1 at
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc503260659
I'm guessing this was all I needed to do?
Yes. Should work.
